Discuss Grundfos UPM3 pump won't turn despite being clean in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi there,
I've got a stuck Grundfus pump again, but this time the usual tricks don't work. I took it out, cleaned it, still won't turn.
Hand pressed against the rotating bit, screw pressed in, no movement.
Tried the same both plugged and unplugged. The black propeler thing won't budge.
Is it broken?
I heard that some water pumps need an initial pressure to be able to start unless there is a built in feature which store some pressure when the tap turned off. Do you get enough pressure in the system?
I'd think of testing the winding by a multimeter for continuity.
(I'm not a plumber)
(I'm not a plumber)
It’s a central heating pump, not a shower pump - I thought you were going to stop commenting on things you know nothing about…..
IIRC, the shaft and bearing on that model are ceramic. So, if the impeller has seized I think you're probably out of luck.
Does the pump need to be working to bring the pressure back into the system? (I emptied it in order to take out the pump by switching the far right valve). According to my notes, turning the 2 bottom left black and red valves should start bringing in the pressure. But nothing is hapenning.
Reply to Grundfos UPM3 pump won't turn despite being clean in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
Good afternoon everyone, I hope you're all going to make the most of the sunshine today. For those of you in front of computers, and more...
O
  • Locked
Hi, I'm not a heating engineer and I have no intention of touching our boiler, but I really could do with some friendly advice regarding a...
14K
