Discuss Grundfos MLE 132E speed control in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Yes that’s the device use your phone and the grundfos go app
Update. We got the ir to work and it controls everything the front display does but like was stated it got the "normal" control mode to work, what happens is the pump normally shows stop, then when you push the start/stop button, the mode changes from stop to normal and you would expect the pump to start however it doesn't, it just sits there in normal mode.
So you can see all the settings on your phone etc and make changes / set things ?
Front display? That’s yours as that’s the 132e
I see on the pump you should be able to see a pressure when it’s running correct ?
Are these figures on 0 when not running / off ?
Reply to Grundfos MLE 132E speed control in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Can anyone help, please? I'm looking for a heating system circulation pump for a domestic install, with 3 speeds, where the speed can be toggled...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
I'm trying to set up a Honeywell DU145 ABV with an ALPHA 15-60 130 (Model number 59526443) and work out the speed setting. The pump has one...
2K
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
