Discuss Glowworm spacesave kfb70 _ help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi' all new member. Went to a glowworm space saver kfb 70 which won't fire' forth led light won't come on. Home owner had a engineer out who replaced the PCB, GAS VALVE AND ELECTRODE +LEAD+ NEW APS , but still didn't fire up. When top. Front cover is removed it. Will fire up, run and when demand met " same issue just sparks .
I have checked cleaned up the flue. And heat exchanger and fan. Cleaned the injector.
Fan dose run but could it be failing to that extent .
Any help. Would be much appreciated.
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Reply to Glowworm spacesave kfb70 _ help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
