Discuss Glowworm compact 80e in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What's the temp diff between f&r zeebeedee? If flows mad hot and return cold in comparison then blockage sounds the most likely! Got caught out once with this sort of fault though, the custard had turned all the rads off bar one
Not familiar with the boiler but it may have a filter on the boiler return that could be blocked?
First thoughts
Central heating only fires fir 10 seconds no lockout hot water ok. Divertor valve and motor ok pump ok. Rads get luke warm.
Sludge? But wouldn't it lock out?
First thoughts
Don't know where that came from!
Filter under the pump was blocked solid!
how did you get the filter out. from underneath by removing the iso valve ? or did you have to take the pump housing out
Reply to Glowworm compact 80e in the Plumbing Jobs | The Job-board area at PlumbersForums.net
