Discuss Glowworm 50FF cutting out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DeeplyDrippy
Greetings all.
Called my plumber out 2 weeks ago to fix my boiler and a radiator that was cold. He couldnt find anything wrong with the boiler so just did a service on it as best he could. He also fixed the radiator.
The fault I have, which is kind of intermittent, I'd say 80% it doesnt run properly, 20% it does, is: The hot water doesnt get hot enough, after a day or two it's tepid at best. Also the boiler cuts out before the house is up to to the 21° I set the thermostat to. I have to keep lowering the thermostat down to 14 or so then back up to 21 to trigger it into firing the boiler again.
My next step I think is to contact glowworm and get them to send an engineer out. They have quoted a fixed price of £118 plus £60 for one spare part, £90 for two.
Before I do that I just wondered if anyone thought it might be worth me just ordering and trying a new thermistor first? Pretty sure I changed one on a 40ff I had at my previous property so it cant be that tricky.
Any advice appreciated.
get in a qualified engineer who can hopefully diagnose and fix it for you safely
I did, last week. Anyway booked glowworm now. This morning hot water working perfectly. Should go wrong again before he visits next week though, hate intermittent faults.
Reply to Glowworm 50FF cutting out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Vaillant ecofit pure, we had it installed about 6 years ago so it's not an old boiler, a new pump was also fitted at the same time...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
C
Apologies - I am not a plumber - not sure if it is ok to post here but... It's freezing and my boiler is not working so, I wonder if anyone can...
Hello, just joined with a question: I’ve two self cutting taps that need removing as they’re stopping a relocated dishwasher from getting back...
