Discuss Getting hot water but no heat to radiators. in the USA area at PlumbersForums.net
I am abit stuck and cant really find a solution anywhere..
So, i have an F&E gravity system. The central heating pump needed replacing as the shaft had seized, changed it all well and good pump working lovely.
I am getting only hot water
The mid position valve is on the middle setting , if hot water only its on water only and heating is on the heating setting. So the actuator works fine..
Just nothing is passing through the radiator circuit from that valve.
Ive drained the system twice and bled the system..
Ive bled the boiler aswell. Ive ran out of ideas, if no solution i guess its a call to the local plumber!
Thankyou
Did you bleed the pump these can become air locked loosen the screw on the front of the pump ? With a suitable container under there and an old towel run the system on heating only to start with gravity systems are notorious for air locking.
Its a self bleeding pump i replaced with the old one like for like the old one had a screw but this one is just a blanked cap and cant be undone?
Dosnt sound like an airlock the pump is running really quiet?
Well if it’s not an air lock, although the 3 port valve is moving position, it might not be moving on the spindle? do you know if the head is detachable? Starting from cold, if you select just heating does the boiler fire up and the pump and pies get hot?
It is detachable if i turn heating on/off you can see the spindle turn and on the body of the valve you can freely move it with your fingers . Yeah just heating the pump and pipes get hot it is just the radiator pipes not hot
So in the picture the pipe going to the right is really cold
Looks as if it could be some pump "problem".
Check that the pump is orientated correctly (same way as last one) arrow on pump body should be pointing at the mid position valve. Pointing UPWARDS (just saw a bit of the pump)
Check pump mode and setting, some have a auto setting mode which is completely useless on most. Can you post or photo the actual pump make, model and mode, and setting, may be able to assist.
Thanks everyone, i did put the pump upside down whst a doughnut to be honest been scratching my head for like 12 hours. Had to bleed everything on the system including the hot water tank in airing cupboard... 30 minutes later radiators come on nice and hot.
Thanks for your help, this was my last resort before calling someone 😄
Very good. At last, good to hear that the Auto Adapt is working well.
I think that pump also displays the power output in watts (W), if so, when you get a chance, you might post the power outputs in CH only, HW only, and CH+HW.
Thanks.
Reply to Getting hot water but no heat to radiators. in the USA area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
