Discuss gas terms in the Plumbing Jobs | The Job-board area at PlumbersForums.net
supper plumb
dont do gas but when i read posts theres short hand spelling like ID etc whats it mean and how many are there? same for plumbing
if im looking for a part or fitting a part etc i call it what it is..
FUBAR = Broken
Jargon, to pee you off! The rule should be if you use acronyms put the full words in first then put the acronym in brackets just after. You can then use the acronym there after and have half a chance of knowing what is being said. Text speak is the other annoyance, you might as well put it in full.
(text speak is great. Saves me loads of time) My daughter marks me at 90% for text interpretation. Still annoying though.
It's a bit like swearing for punctuation, makes you appear a bit of an uneducated chimp.
Excellent and informative read. Are you in the apostrophise poliza?
Expert witness for the gas/plumbing industry. Way with words, but still can not spell.
Reply to gas terms in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for a commercial gas engineer to assist with servicing, callouts etc. work is mostly london based but also have sites in kent/essex...
1K
Neil Ambrose
N
Im fitting a kitchen in my own house . When removing the gas oven on a bayonet fitting and turned the gas hob off and removed a four burner gas...
Hi, I'm looking for a gas engineer who I can work with so I can complete my portfolio. I have done level 2 and 3 tech cert along with bpec gas...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
