Discuss Gas supply not working..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
maff00
Hi.
I have an ecotec24 in a new flat I have moved in to.
It is a brand new renovation and I believe the developer had the gas supply reinstated.
I have yet to be able to switch the boiler on as there appears to be no gas getting to it.
Does the regulator on the Gas supply need resetting or something?
I have checked the gas tap in both the off and on position.
The developer is not available as on holiday, but I need to turn the combi on.
Does anyone have any pointers?
Kindest
Matt
How has the boiler been commission and set up then / do you know if it has been done ?
I have no idea at the moment. I suspect it should have been commissioned but I can't be sure until I speak to the developer. I just wanted to establish if I was overlooking something obvious. There is an f.28 fault showing.
Sorry to say until you know it's been commissioned I wouldn't turn it on
Wouldn`t the OP been given the paperwork if it was safe to use? What do you call it the Benchmark?
Depends normally no just the landlord
OK. I will leave alone till I speak to developer. Just going to buy electric heater from Argos so hopefully should be warm tonight. Thanks anyway.
1. do you have any other gas appliance in the property ? are they working ? Have you turned on the gas next to the meter ? is the gas tap below the boiler on ?
Reply to Gas supply not working..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
