Discuss gas safe test in a year time from now in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
ill be sitting my gas safe test in a years time. i am a bit nervous cause my mathematics is not my strongest point. I've briefly look at the formulas that are used to calculate the volumes of gas is required and used.
any advice and recommadations that what i can do now to get set with confidents.
what did people do when this plumbingforum was not here for advice.
Most colleges now allow use of an app for common calculations - mine certainly does.
You're allowed to use a reference book and calculator even if they don't.
The assessors are usually pretty good at helping you feel at ease. I'm sure you'll be fine.
everything about the gas test. i had a read through the gas books that i downloaded from yourself. its quit scary theres a lot of information about gas regulations and working gas rates and pipe sizing.
All the information you need will be available to you. You won't need any apps for it. You just need to listen to the advice in the training centre and look though the books and info provided.
Practice makes it perfect... If a bear can ride a bicycle - you can learn anything you want to. Are you saying you are not better than a bear!?
I thought that was Croppie at first glance......then remembered he rides a tricycle.
Stop worrying. It is easy. Basic arithmetic.
Reply to gas safe test in a year time from now in the Plumbing Jobs | The Job-board area at PlumbersForums.net
