Discuss Gas pipe work under floor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
fubar1000
Morning all
Went to quote for a new boiler last night, but as the custard is having some building works done at the same time I've got a lot of pipe work to hide. This is not much of a problem, but the custard wants the new gas main to run on the floor though his garage (which he is having converted in to kitchen / dining room) & will be screeded.
Can I run trac-pipe on the floor & then have it screeded over????
Thanks gents
You can, but it is very expensive material. Price match it against plastic coated copper and allow a little extra for labour costs on the copper.
Don't know why it should be so expensive. It puts alot of people off using it.
I priced it up in trac-pipe & wasn't to bad TBH, less than £200 with fittings & 10 meters of pipe
I think by doing it with trac-pipe will save a lot on labour
But you get paid for the labour? Lol
What's the point of the quick expensive option if you can go with the intensive cheap option and get more from it?
or charge the same labour and make more profit because your have used your brain and made your install quicker :)
Reply to Gas pipe work under floor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have decided to remove the timber floor boards and joists as they are effected by damp and rotting. Was hoping to infill and have slab and...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the...
I have a badly blocked feed pipe to kitchen rad, was running very slowly but I’ve made it much worse trying to clear blockage with curtain wire...
