- Messages
- 34,374
- Solutions
- 2
26.9 ?
So you give an appliance a service after you replace a water part for free
In the real world no one does anything more than a visual
Unless theve changed something that would effect them
Discuss Gas Engineers > What is the correct procedure attending a boiler breakdown? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
26.9 ?
Who mentioned a service? You are REQUIRED to conduct the tests outlined in 26.9 whenever you work on a gas appliance. Or does repairing/replacing a diverter valve not count as working in a boiler?
Jeez. You may call that a service. You have no idea to what I am referring, do you?
Yes 26.9 Reference is
Flue gases
Combustion air
Op pressure / input
Operation
Which in turn is the same as you would do in servicing
But you will not comply with the regs? Bit surprised, Shaun, did not expect that of you
Shaun. 26.9 is NOT a service. It is the minimum required when attending a gas appliance. Even if you are there to top up an EV, your attention and subsequent leaving it working counts as an affirmation that all is safe with the boiler. The regs demand that, to be sure, you complete 26.9.
Really, what bit do you not understand?
Reply to Gas Engineers > What is the correct procedure attending a boiler breakdown? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
