Discuss Gas consumption for new supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
magicno1
Hi all.
We are doing a large renovation with one 40 kw boiler which will run a 5 bed house and one 30kw boiler that runs a b&b annexe with 4 bedrooms and en suites.
One range cooker and one fire also.
My customer is trying to fill out the new application form for a new supply and they want hourly consumption in kWh and annual consumption in kWh.
Can somebody help how we can sort this please?
Hope your commercial :)
Need to keep the total gas load under 70kw
But don't forget combis won't run more than one outlet
Ok so say it is 70kw then how do we get the figures required?
Can give you the m3/h which is normally ok for the suppliers
Then get one isolating valve with an upstream test point for each property so that you can test from there, you then don't need to touch the bigger meter.
Reply to Gas consumption for new supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
