- Messages
- 34,366
- Solutions
- 2
anyone seen a mechanical flush pipe cone / washer i can remember seeing one somewhere but i cant think where
Discuss .....flush cone...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do you mean these or something completely different?
Toilet Flush Pipe Sealing Ring | Stevenson Plumbing & Electrical Supplies
Have used the ones above but never a mechanical one.
Blimey. Think it will hold ok?Yea had a toilet today that was like 10mm bigger od of the flush cone so had to use the existing and some mastic
Ah, I remember they advertised it by picking the pan up by the flush pipe.
Sorry Shaun I can’t remember what it’s called either!
Bugging me now!
Three Allen bolts and it expanded like a drain bung...
I’ll ask at merchants tomorrow, don’t think they sold any so they disappeared.
Expensive, and solving an almost non existent problem - as a lot of these things do... - bit like that fluxinator thing...
Chris Jepp invented it and there is a utube video, I think he trades from Bexleyheath from a plumbing and heating outfit there. Rob Foster aka centralheatking if you do contact him give Chris my regards from API 2006Ah, I remember they advertised it by picking the pan up by the flush pipe.
Bugging me now!
That is a recurring problem anybody can patent something that does not work or produce something that nobody wants in sufficient volumes to make it viable...Rob Foster aka centralheatkingI’ll ask at merchants tomorrow, don’t think they sold any so they disappeared.
Even the rubber one?Because I’ve found a pan with a 10mm bigger dia than a normal flush cone
You can put a normal one in a wiggle it around
Our merchants have three sizes of “normal” flush cone. I always found one to fit, I’m guessing it’s not a new installation as pan would come with correct one (usually)
Can you reuse the flushpipe and cone from the old one?
Yep ...to...Jepp ?
Reply to .....flush cone...... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
