Discuss Flue Gas Analyser advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
brum
Hi guys I'm looking for an analyser to use on oil boilers to help me in commissioning prob buy a second user model will probably only use a dozen or so times a year initially needing something easy to use.Any advice would be welcomed cheers...brum
If you are only going to be using it a dozen times a year, then it would take a year before it will start to pay for itself, but I would go with a brand new analyser, rather than used.
For oil you don't need anything better than the Testo 310. You can get it with a printer kit also. Expect to pay about £500 inc vat.
Very well built and easy to use once you get started.
Others no doubt will recommend the Kane analyser with the user friendly dial.
Remember all analysers need to be calibrated once a year
My plan was to but I've been doing loads of installation work....not really what I wanted but hey ho btw how you keeping young man ive not been on here for ages had no pc found it difficult on phone , ....brum
I have a Testo. My old one was a Testo too. I can't fault them. I use it on Gas and Oil.
I don't know if this is just me being belt and braces but I would also recommend getting the manual smoke test equipment. (looks like a bike pump). I use it first , to avoid putting too much smoke and muck through my Testo.
There's no oftec required in Scotland so I can fit and forget just thinking ahead
I think it's best to set things up right. I'd buy one if I were you just so I know it's burning right. They do make life a lot easier.
dont they come with the fga?
ive seen a few pics with them in
Like this !
Totally agree with Last Plumber, - get a smoke pump and some smoke filter paper to test any boilers you are not sure of how they are running before you use the analyser. This should ensure you don't dirty the filters.
In fact, an oil boiler can be set very well just using an oil gauge and a smoke pump and a bit of experience. An analyser used afterwards would hopefully prove it.
My plan was to but I've been doing loads of installation work....not really what I wanted but hey ho btw how you keeping young man ive not been on here for ages had no pc found it difficult on phone , ..brum
Good to hear from you Brum! Was surprised to see your name on here. It has been a while.
I am doing well. :)
You wouldn't want to have the extra cost of a smoke pump everytime you buy a oil analyser. They cost about £100 and last forever if looked after.
You're not kidding there. Mine is now around 50 !
at a guess. Maybe older than that to be honest.
Crikey! Mine is only half that age.
You obviously are taking care of it and assume greasing it.
I haven't been using mine recently and just careful with analyser. My filters never look dirty.
I did grease it not too long ago.
It was bought with the full kit.
images
images
There are other things like flue gas temperature gauges
Similar to my old kit. Ancient looking now compared with modern analysers. I was always wary of getting wrong readings if any of the one way valves failed in the squeeze bulb.
I prefer analysers because they constantly give readings while you can adjust settings, plus you get all values.
As @Best has mentioned testo 310 top quality analyser
. You cannot go wrong with that. You can get a kit with a pump as well and printer
Cheers best appreciated think I need to sit down and send out some invoices lol ..brum
It will be something you wished you had bought long ago.
Just work out how you can source a few extra oil boiler jobs to pay for it
Reply to Flue Gas Analyser advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
