Discuss flue bracket spacing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
derrybongo
Hi All
Does anyone know where i can find some info on the proper spacing/distance of flue brackets on a horizontal flue run.
Generally 1 bracket / extension and change of direction. Just use common sense.
From Worcs mi's
Support the flue at approximately one metre intervals and at a change of direction, use suitable
brackets and fittings (Flue bracket part numbers.: 100mm - 7 716 191 092, 125mm - 8 716 110 272).
From Vaillants
☞ Use one clip per extension to
support the air/flue duct.
Baxi
IMPORTANT: All flue systems must be securely
supported at least once every metre. Suitable pipe
supports are available as accessories.
cheers Tamz
done a landlords today and the flu went through the length of the Kitchen approx 12 feet and then out the wall with a join in the middle and no proper support looked to be a little sag there i tried to find some info in the MIs to no avail and had a look through my book when i come home but couldnt find anything. will take some brackets with me when i go back to do another job tomorrow. i asked who done the work but he couldnt seem to remember.
They never do remember! There must be a lot of faceless plumbers going around lol
Nah. Usually this guy or one of his mates lol
Reply to flue bracket spacing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I believe this boiler can be changed to a system or combi. Does this mean the hot and cold tails have to be blanked off?? Also the horizontal...
My son moved to a new build home in Cornwall last November. Yesterday evening he found a quantity of water beneath the Ideal Combi boiler and a...
The flue for a glow worm micron 30ff is apparently obsolete but there must be other flues that would fit it surely, it's just a standard 100mm...
Hello All, I was hoping you could help with a potential boiler build query for my father. He has recently had a new boiler installed via British...
