Currently reading:
Flexis on to iso valve or Male Coupler 15mm x ½"
Discuss Flexis on to iso valve or Male Coupler 15mm x ½" in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey when fitting a tap supplied with flexis with a 1/2 female end. Do people screw them on to a iso valve or a male coupler 15mm x 1/2. I have used iso valves in the past but hear your not meant to as it doesn't have a flat surface for the washer to sit on.
People do but your not ment to toolstation do a handy converter or a standard half inch converter is Bob on
So have I sometimes filing down the thread on the service valve to give a flatter service. Is the fitting have put the link to the fitting your meant to use though? Giving a flat surface for the washer
Yes you should really go on to the correct fitting if your going by the book.
I always flatten off the top of the valve with a diamond file I like to have a flatish surface for the rubber washer to seat on gives me piece of mind
I go to a few of these a week where the washer in the flexi has deteriorated and failed when installed straight onto an isolator.
15mm to 1/2 inch male iron is by far the better way of doing it. I've never seen one fail.
Reply to Flexis on to iso valve or Male Coupler 15mm x ½" in the Plumbing Jobs | The Job-board area at PlumbersForums.net
