they are a major problem, they regularly burst and insurance companies hate them, but being diy you just see them as an easy option. You have been warned.
I'm happy to try and convert to rigid if i can work out how to do it.
Discuss Flexi hoses in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If you are using them check that the are at least WRAS approved, also I would use the fuller bore ones and replace that restrictive isolation valve.
which is why I also said use fuller bore flexisTBH the tap connector seems to restrict the flow to such an extent that the isolation valve prob makes little difference!
BTW there must be tends of thousands of hosues fitted with these by now - surely if they wre a MAJOR problem it would be more well publicised?
Reply to Flexi hoses in the Plumbing Jobs | The Job-board area at PlumbersForums.net
