Discuss Fitting European shower trap to 40mm waste pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Thanks Ben,
That sounds like a very pragmatic (and cheap!) solution. The cut does not have to be too square as it is a solvent weld join so plenty of room on the sleeve.
So have started fitting all the bits together and so far, so good. Thanks to everyone for their suggestions.
The mini-hacksaw blade with a piece of cloth wrapped round it and bent at 90 degrees ended up being the best bet. I tried my dremel but just didn't have enough room to use it. So long as the blade is new it cuts really well with hardly any back and forth motion.
Reply to Fitting European shower trap to 40mm waste pipe in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi I'm currently doing the pre-planning for my next DIY project fitting a shower tray and enclosure from scratch. I'm confident of being able to...
I have bought a shower tray and it has an extra large hole for the waste trap. Its a cooke and lewis think its an eclips 1400 x 900 tray. The hole...
plumber has not fitted water supply pipes level to tiles in shower, one side is approx 5-7 mm out of line, can i fit some sort of extension to...
