Discuss Fit fused timer for old oil boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys,
Have an old Oil Myson boiler that works fine, barring the mechanical timer on the front. Timer makes a sound but isn't going around so left using boiler manually.
Any ideas how to fix the timer?
Pic of boiler :
Alternatively could I fit this fused timer where the current fused switch is:
https://www.NoLinkingToThis/p/green...ay-fused-digital-timer-spur-switch-230v/7643g
set the time on that and leave the boiler set to continuous all the time?
Pic of fused switch above boiler:
Just worried the switch cutting the power while boiler is on could cause some kind of problem as when you switch it to off a fan sound runs for a few minutes after.
Any help much appreciated
I have had the same problem with several
customers’ old oil boilers.
In all cases I have fitted a remote Honeywell ST699
all were very pleased especially as the 699 is very easy to us, if a little expensive.
A fairly straightforward job.
Reply to Fit fused timer for old oil boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
