Discuss First fixing shower watse on new builds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks, is the shower tray needed or at least the dimensions off it to make sure the waste pipe is the right side of the joists to the shower tray waste outlet. As they tend to be in different places.
Which would mean a riser kit or different tray. Is there a set distant you leave the pipe below the floor so its not too high for the tray, guessing a couple of inch to top of pipe will be ok?Yes, - better you know what tray & waste position. I would also check tray waste hole position incase it is directly where a joist is!
Reply to First fixing shower watse on new builds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
