if the reason you say not to use hair felt because of the cupric-ammonium complex ion being formed because of ammonia being present as a result of decay of organisms in the hair felt then, 5 factors are needed to cause cracking of the pipe. water, oxygen, tensile strength, metal that is susceptable and ammonia. And oxygen is the main 'ingrediant'! this ammonial reaction effect mostly copper alloys, such as brass are most 'suseptable' copper on its own has low to very low reaction to ammonial corrosion. also if the pipes are screeded where is the oxygen to assist in this process? is there ammonia in wras approved felt lagging and if your still in doubt (and still want to use copper instead of plastic) couldnt you pre protect the pipe as im sure most would anyway with duct tape or something. then lagg it. all in all id say its a low chance in these circumsatnces. but thank you for your point, iv found it very interesting researching your oppinion, it does happen, which i didnt know before. thanks again
