Discuss Filter under sink query/advice in the USA area at PlumbersForums.net
Morning everyone,
Does anyone know anything about the following product and if its pretty straightforward to install as I want it for under my kitchen sink:
It looks like the hoses supplied are wras approved, not the unit.
Avoid.
Btw i advise against those inline filters, eventually they get forgotten about and end up filled with huge amounts of biofilm - like grey ish slime.
Mains water in uk is wholesome by law. If you doubt that, contact your water supplier for info.
Thank you for the advice and I will avoid the product.
I am just looking for something simple to test the drinking water from the cold tap in the kitchen as sometimes it tastes a little bitter.
I have a single mixer lever tap and any tips on which water filter faucet would be good which you can easily put on the tap?
The tap is part of the plumbing system. If there's something wrong with your water report it to the supplier you pay for the water. If not leave it alone.
If it's only you that thinks it tastes 'bitter' and it used to be okay, you may have a bad tooth. If the bitterness seems to build up with the length of time since the tap was last run it might be dissolved copper due to corrosion.
As others have said, first step is to report the issue to your supply water company.
Reply to Filter under sink query/advice in the USA area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
