Discuss ferroli modena 102 standard efficincy in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 32524
Hello all,
Need some help with above boiler. Keeps cutting out on hot water and CH. Works fine with cover off. Thermistors test ok. Replaced venturi, no joy. Got to be an air problem but what? No blockage in flue.
Thanks for the help.
Duncan
Hello all,
Duncan
Tired fan. APS
Clean fan and lubricate.
Remove restrictor ring from flue also
Reply to ferroli modena 102 standard efficincy in the Plumbing Jobs | The Job-board area at PlumbersForums.net
looking at a modena 102, it starts up and runs fine on hot water and heating, but after a min or two it locks out. found a faulty thermistor...
Hi lads and lasses, I have this customer that has to keep forcing mains pressure back through his vented hot water system every week due to a...
3K
Hello. As stated above my saunier duval themaclassic f30e isn’t firing up and is giving an F1 fault code. I’ve taken the front off and opened up...
1K
Hello - just wondering if anyone has any ideas why my Worcester 24i combi boiler doesn't heat the central heating water? It heats the tap water...
2K
  • Locked
Hi all, I've got a British Gas 330+ Heat only boiler and it displayed an F25 error (lack of water iirc) on Sunday. I read the manual and bled the...
2K
