Discuss Ferroli Modena 102 Boiler Keeps going into standby mode in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Staffy77
I had to change the water pump due to the connector burning out and was tripping my fuse box. The boiler now works for DHW and CH but once the demand stops, LED 4 flashes / goes into standby mode for 2 mins, then resets and all functions can be used again.... Any ideas what I should check? PCB seems OK, pump is running fine, there are no solder issues, relays seem to be working fine, pressure is good.
yes please get and use the services of a gas safe engy
We seem to be getting an influx of have a go heroes just lately.
Get a gsr in. You are neither competent nor qualified to open a boiler up. Removal of the case is classified as gas work.
Reply to Ferroli Modena 102 Boiler Keeps going into standby mode in the Plumbing Jobs | The Job-board area at PlumbersForums.net
