Discuss Ferroli HE 31c F37 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
logjam32
Hi everyone, I've recently replaced the pcb on my ferroli he31c boiler and its since come up with an F37 code (system pressure switch). The thing is when I put my old pcb back in it goes through its sequences etc and although doesnt ignite no error comes up. I've been having problems with relays on the board hence me changing it. Can you tell me if its a pcb parameter setting that needs to be changed so it recognizes the switch. If so do you have any ideas which setting needs to be changed.
Many thanks in advance for your help regarding this
Hi guys, no the boiler doesnt fire up at all. It just goes straight to F37. Not gsr, am electrician and thoguht it'd be a simple enough process changing the board. Thought It'd just be a parameter needing changing for it to recognise the low flow switch. Be greatful for any guidance.
Check boiler pressure is slightly above 1.5 bar to be sure, failing that you will need a gse
Thanks southcoastboile, have checked the pressure, thats ok. Will wait till get paid and get a gsr on it. They quoted £75 call out fee.
Thanks anyway for taking the time to respond guys, much appreciated.
Reply to Ferroli HE 31c F37 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
Hi, Have a Valliant Ecotec Plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating. Have...
1K
Folks Me again I am at my wits end. I want to replace the boiler but I am on my backside and cannot afford to. I have been getting an...
Deleted member 120897
