Discuss EPH COMBI PACK 4 to ida in the Central Heating Forum area at PlumbersForums.net
Hi there
Advice needed having a eph combi pack 4 fitted to my ideal vogue c40 gen 2 boiler 2017 model the wiring change on post 2019 boilers. Do I need a separate power supply for the reciever or can this be powered from the boiler. It will be connected via open therm.
Many thanks
Yes take all wiring from the ideal - although opening up current ideal boilers means disturbing the combustion circuit, which should be checked for safety afterwards. LNE and OT can all be ran from boiler.
Reply to EPH COMBI PACK 4 to ida in the Central Heating Forum area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
