Discuss Emergency Plumber. Out of hours. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
moonlight
I dont think the person who did this should call themselves a Plumber:eek:
No wonder the toilet kept running :eek:. Nice new valve fitted.
Trading standards now involved.
The plumber surely didn't charge anything for that bodge?
You wouldn't believe me, he also fitted the cheapest mono block tap possible and charged her £400 :eek::eek:
He has got a weeks wages from her, for what should have been a couple hours work probably maximum. :eek:
Too many rip off merchants out there. I get stuff like this sometimes. It winds me up.
Obviously the cistern was still running, she contacted the emergency plumbing company asking for it to be put right. No joy. Trading standards now involved. Good job I kept the picture will be used as evidence too.
I hate shoddy work. Call themselves Plumbers. Disgusting.
It would have been a disgustingly high price even if the work had have been professionally done!
thats the best one ive seen in a long while :D
The painful thing about this one is that the guy who did it was clearly not stupid. They had a replacement float valve but it was too big to fit in the cistern. Okay, they modified it and even used two screws to make sure the join was strong. But it was jamming because the float was touching the back of the cistern. The spare low (? red, anyway) pressure seating came to the rescue as a sliding spacer keeping the float away from the back. This works because it's been positioned it close to the hinge where the mechanical advantage can overcome the friction.
If he had put a bracket across both sides of the arm, would have been temporarily fixed. It dips in the middle. If he is not that stupid :rolleyes: why didn't he just take the diaphragm out of the new one and repair the old one, or even take the arm off the old one. Most definitely stupid.:eek:
Depending just how out-of-ours the job was I could see it being a £300 ish job (with monobloc tap supply/fit inc too.) But presuming not 3am in London, yes, a rip-off.
If you keep no more than 7 or 8 different float/inlet valves on the van then you will have one for every situation.
Looks like good situation for one of these (but they are pricey.)
http://www.NoLinkingToThis/p/thomas...bottom-inlet-fill-valve-with-delay-fill/4777r
That's what it has now, should have posted the after picture too.
Well you have all missed the point. You can not know the circumstances relaling to this clever fix . But please understand that the only way you can sensibly deal with these old cistern parts is to change them all. I do, and charge £68 plus vat with three year warranty..... maybe misguided but he did try!
Well you have all missed the point. You can not know the circumstances relaling to this clever fix . But please understand that the only way you can sensibly deal with these old cistern parts is to change them all. I do, and charge £68 plus vat with three year warranty... maybe misguided but he did try!
If he didn't have the correct part he should have isolated the supply. Very poor workmanship. This will never stop filling. Far from clever. Take a good look at the picture. I went to repair the mess he left.
Reply to Emergency Plumber. Out of hours. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We had an incident of estate water pipe burst and united utility had to fix the issue for the whole estate and this time we didnt have much water...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by...
TheCatWhoNeedsaHotShower
T
