Discuss Electric magnetic descaler in the USA area at PlumbersForums.net
Hello!
I would like to use this electric descaler to soften both the hot and cold water in the house.
I was thinking I needed to purchase 2 of these, one for the cold pipe into combi boiler, one for cold pipe just after main stopcock from mains. Is my thinking correct?
Thank you in advance.
They are not your answer if you want to soften your water!
Bite the bullet and get a salt based softener - you will not regret it and, if you buy the right one, will be a long term investment and last a life time!
Do a search on this forum on Water Softeners and you will find tons of information from the professionals.
Why are you confusing scale inhibiting devices with water softening systems?
These devices don't soften the water at best they inhibit the formation of scale from sticking to surfaces, in my opinion the only true way of softening.wster is via a salt water softener. Kop
Reply to Electric magnetic descaler in the USA area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
Hi, I was hoping to get some advice. I live in a three floor house with a gravity fed cold water system for all of the bathrooms. The tank is in...
