Discuss Electric boiler and an unvented indirect hot water cylinder in the Central Heating Forum area at PlumbersForums.net
Hi, I have recently purchased a cottage with an LPG combi boiler (no mains gas in the area). I intend to replace this with an electric boiler and an unvented indirect hot water cylinder.
The boiler will run four radiators and the hot water cylinder. The cottage has one bedroom.
What size (kw) would I need for this system, I was thinking that a electric boiler with an output of around 6kw would be enough.
Your thoughts please.
Many thanks
David
What are the output of the 4 rads ?
If you have six radiators, you should get a 9 kW electric boiler. This rule may vary depending on how high your ceilings are, whether you have single or double glazing and how effective your insulation is.
If you go for HW priority then you'll get away with just your CH requirement. Otherwise you'll have to add a few kW for hot water.
Reply to Electric boiler and an unvented indirect hot water cylinder in the Central Heating Forum area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Is it worth replacing a Potterton gold 9kw electric boiler with a hot water storage tank for a new Electric Combi Boiler ? Would there a...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
