Discuss Dual Flow kitchen taps and bath deck mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone advise on makes/models of dual flow mono kitchen mixer taps that work for mixed pressure feed suppies - gravity hot and mains cold ?
Also same for a bath deck mixer ?
I know it can be a pain sometimes finding a tap that doesnt force the cold back through the hot pipe when both taps are opened together.
Thanks in advance.
With a deck mixer, the actual valves are not combined, they're at each side, so you should be fine with any deck mixer as the mixed water will come out of the tap spout, water will take the easiest route.
Same goes for kitchen if you get a deck type mixer.
The point of that kind of 'laminar flow' is to stop the mixing and possible contamination as you say. If you fit NRVs in both lines that does the same I believe.
Correct regarding your reasons for fitting NRV's but this will also restrict the flow through the hot so want to avoid installing any
If you would like advice on here might I suggest you give people appropriate information upon which they can off that advice. Otherwise, like I feel now, they will simply not bother. Good luck and I hope someone manages to read your mind in a manner that satisfies you... :rolleyes:
Kitchen tap isnt to much of a problem, struggling a bit for a dual flow bath/shower deck mixer tho
You won't find a dual flow bath/shower mixer. The purpose of a dual flow is that the hot and cold supplies mix only after exiting the tap outlet. A bath/shower mixer cannot achieve this. Some of these come fitted with built in single check valves which will prevent backflow but for those without them built in, you are required by the water regs to install them on the inlet pipe. Whether this restricts flow or not is irellevent as it's the law.
Reply to Dual Flow kitchen taps and bath deck mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
