Discuss dripping drain off on vented central heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If a drain off valve is leaking on a vented central heating system, due to not shutting off. As the washer has perished. Has anyone had success in swapping the inners over in this without draining down, if quick?
Do mean an mt cock ? Its a drain for heating system located below the head of water for the system. .Rob Foster aka centralheatking
I have had to unscrew and remove the brass part and sometimes poke a small slotted screwdriver in the drain to break/remove the old washer.
This is a good reason for not using soldered draincocks, but rather 1/2” threaded into F.I. fittings where suitable, so the entire draincock can be swapped easy
Reply to dripping drain off on vented central heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
PSxxxxxx
