Discuss Drayton Digistat No Working! No Heating Upstairs! in the Central Heating Forum area at PlumbersForums.net
Morning All
I have a Valliant Ecotec Plus boiler which runs our under floor heating at ground floor and rads on the first and second floors. Both systems are controlled via a Drayton Digistat SCR with a receiver on the ground floor and the other on the first floor. All has been working well for the past 3yrs until Tuesday this week. I woke up to cold rads on the first and second floors. I checked the Digistat receiver and it appears to be working fine i.e. displaying the usual icons including the flame. I replaced the batteries and reset it with the SCR but still no heating. As far as I can tell the boiler is working OK as I have hot water and heating via the underfloor system. I am at a loss and would therefore welcome any advice. Thanks in advance.
Probably zonevalve for the radiators not working .
If you can identify which one if it has a manual lever try latching it open rads would then work whenever boiler works for any other part of system.
Failing that need a multimeter and be competent to use it.
Many thanks. It’s all radiators upstairs that aren’t on. It’s as though the Digistat SCR isn’t picking up the receiver that’s upstairs even though it’s on. Or the boiler isn’t able to fire up the radiators?
As you have 2 separate areas for heating you will almost certainly have zone valves somewhere look for silver or white box with a cable from it attached to .pipework.
Ah Yes! I found found them and they appear to be as they were! When the heating is on they are both hot to touch which I think is normal? Photo attached For referenc. Thanks again!
Is the lever free to move up and down with everything on ?
Rads and ufh set to on / heat
Reply to Drayton Digistat No Working! No Heating Upstairs! in the Central Heating Forum area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Hi, wonder if anyone can give some advice. Recently moved into a new property. It has external OIL combi boiler which is new and works well...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
