Discuss Draining heating system - no water coming out in the USA area at PlumbersForums.net
I need to drain my heating system. I located the downstairs radiator with the drain off valve, attached a hosepipe and turned the valve...nothing comes out.
I've tried this on all the downstairs radiators with drain off valve, again nothing comes out. I tried to bleed the upstairs radiators to help it along but only water comes out, so there's definitely water in the system
The house is ten years old. Any ideas would be gratefully received. Thanks!
How far did you undo the drain off? Also they could be stuck (happens usually on older systems), only other way is drain through the valve(s): attach a short piece of copper in the hose with a nut and olive and attach to one valve (afte disconnecting from the rad of course), and using a split compression stop end to plug the tail of the rad.
Reply to Draining heating system - no water coming out in the USA area at PlumbersForums.net
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
Hi, I drained the the central heating, to remove a radiator. After refilling it, the heating now won’t work. It’s a combi . I’m getting this symbol
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the...
Hi guys, just want to get some advise, basically new vaillant regular boiler has been fitted approx 5 yrs ago, i believe it was back boiler...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
