Discuss Drain down a Worcester Hi-Flow 550cdi boiler in the Central Heating Forum area at PlumbersForums.net
J
John Holt
I have the boiler as above which has been very good for the last 13 years or more and is still relatively going strong.
However, now, the secondary heat exchanger is kettling and the easiest option is to replace it.
Although Worcester Bosch do sell a cleaning kit, whatever route I take, I'll still need to drain down the heat store.
There's plenty of advice on how to drain the central heating system available online but no instructions on how to drain just the DHW and heat store.
Maybe draining the central heating system also drains the thermal store - I don't know.
So, any advice/tips etc welcome.
Thanks in advance.
Reply to Drain down a Worcester Hi-Flow 550cdi boiler in the Central Heating Forum area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to sort all of my rads and do some other bits including fitting a filter but I'm stumped on how to drain down due to how the system is put together...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small 3rd floor flat, I have a radiator in the front room and one in the hall (very close to each other), there is a drainage valve on one of these. My back...
Hi guys just wondering how to top up pressure on this Worcester boiler after draining system down Also an unvented cylinder upstairs and solar panels Many thanks
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The issue is quite simple to repair not sure why any one of the 2 plumbers could not fix it. Why am I paying for cover. The auto air vents in part of the...
I have an Elson Sapphire double feed indirect hot water tank and I need to drain down the system to move some radiators. Would anyone be able to offer any advice as to the correct drain down and refill procedure for this tank? It is a self contained boxed and insulated unit with a single cold...
1K
