Discuss domestic or commercial gas ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0167
Hi Guys
Went to look at a new build installation today for a builder i do a lot of work for, this is a Massive house and he hasnt had any drawing done he seems to think we can just wing it and hope it will be okay , may get away with that on a normal house but not on this ,
Am i correct in,
the maximum input must not exceed 70kw
iv volume must not exceed 0.035
meter can be u16 but must not exceed the iv
pipework no bigger than 35mm
the problem ive got is this house has got a swimming pool which is being done by a separate pool company and we do not have the specs
if for example we had 50kw input for boiler cooker etc then they come along and fit anything over 20kw we would be over the 70kw allowance
where would stand with doing our work staying in our tollerances and then them coming into do theres ? if it went over our scope then would we still be okay as they have installed after us ?? Ive asked the questions if we need to put any previsions in for them and the answer was a NO NOTHING TO DO WITH US,
surely it would make sense to know what they fitting to enable us to allow for the correct size pipework to the plant room , as we are fitting this , currently the gas meter is between 25 to 30 meters away and its a e6 ,
the impression i got is we only need to look after us , but im thinking is a e6 going to cope are we going to be out of our iv volume if he puts a big bum boiler in where does that leave us ????
I know its a bit sketchy as i dont have any drawing of them on the specs nor do i have the pool specs
Any comments appreciated
Matt
correct
but input is all appliances connected to that meter
and correct unless there having another meter fitted you need to be able to size the gas run for there appliance unless there running a separate gas run
tbh i think your going to struggle with an e6
best to size everything and see where you come out
Hi @ShaunCorbs with out all the information on the pool i know its vague , but from the builders point of view he aint got no involvement in the pool.
if we did our fit and stayed within our scope all commissioned see you later we would be fine within the regs if they hadnt installed anything yes i know they are going to install later but at that time it would still be domestic am i correct ?? ( Backwards job i know surely want to do it one time and the correct size with one gas run to the plant room )
Second scenario we start fitting and then they come and and run there own gas line and associated appliances which then exceeds our IV or KW , that then takes us out of our scope . Correct ?
yes you would be fine as its under domestic scope if you worked it out before and comes under etc,
say you finish and all up and running etc then they come and fit there stuff then it would be upto them to size there side and if it goes out of scope its down to them but if they come half way through your first fix and start you could be working out of scope / couldnt finish / need a commercial engy to help
it gets tricky as you see
wheres the house?
Its in Bham @ShaunCorbs just what i thought yeah fine if we do our bit then they come and do there but a month later but it aint going to happen like that , the pool company is surely going to want the builder to leave him some gas electric and mains water in his plant room i can see that and then half way through the fit rocks up with a big bum boiler and then we are out of our scope of works .
your best option is to plan for it only way you can be safe
you need to know the specs / what they require etc
could you contact the pool company direct and ask them ?
yeah i could to be honest but the builder may not like the outcome when i tell him we are working out of our scope,
ill just have to arrange a meeting with him and the pool company and see what they got specified , as for our side of things i know what he will have speciefied , ( ill leave it up to you mate i know you will sort it .... hahah ) Maybe on a smaller scale but not on this level need proper calcs and drawings 5 beds and 4 bathrooms ufh bottom floor ufh middle floor , rads in the loft plus the pool side . dont think a 22mm main will cut it for the hot water and i aint being the one hung out to dry when something is undersized, they think your being funny when you ask for a mechanicial drawing haha
yep and then its your fault / upto you to sort
and stnd as he can blame you when its wrong
dont they have plans drawn up yet?
and these days they wont pay for one to be done down to us :D
yep your right wont pay will they i even gave him a number months ago for a nursing home project which fell on deaf ears, going to have to stand my ground on this one i think
thanks for your help shaun
any problems / questions give us a shout your more than welcome
Reply to domestic or commercial gas ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
Dear all, We were disconnected by our gas supplier. We have no managed to find the money to clear the bill. They have told us it will take 10 days to reconnect us. There is a vulnerable old person in the house and we have no heating or hot water. Also we are worried that the pipes will freeze...
Hi We are a commercial premises Have been using the same plumber for years and very happy with his work but recently came to light he has a domestic ticket. When questioned he said it was ok as all the boilers he works on are under 70kw? He also says he does not touch the commercial catering...
Our House is now fully Heat Pumped, insulated and we have had the Gas Meter Removed. We have a 1950s foldaway Cannon Gas Grill which is on the wall above the AEG Induction hob with 1 Gas burner. It worked very well on Natural gas. We have had the local gas co. install an LPG supply using...
