Discuss Does this water tank look dangerous? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
We are tenants. A neighbour came to report an overflow pipe pouring out onto people. I was trying to stop it when I found the water tanks. The water tank has no lid and is covered in mould. I've turned the water off and have just turned it on to use the tap near the water inlet once or twice a day and have avoided using anything out of this tank. The letting agent has now left us without running water since Saturday and they have not made any booking to send a plumber yet. Is this as dangerous as I think? Due to a rare health condition, food poisoning or similar can easily be fatal to me and my children.
If you have a vented hot water cylinder and a pin holed heating coil then possible that water from the upper feed & expansion tank could backflow through the CWST outlet and contaminate the CWST, unlikely, you should hear water trickling into the F&E tank and water slowly filling the CWST. Is the mains cold water clear/clean?.
Try and look into the F&E tank and see if clean as well, again unlikely but possibility that the vent into this tank is pitching occasionally and slight overflow might be gaining access to the CWST through the the common teed in overflows?.
The water appears okay in the kitchen, that is next to the water meter. The water in the upper floors doesn't look as clean. I've always been worried about the hot water. I think we'll have to keep the water off then until the letting agent can be bothered to send someone out to fix it. I don't want to risk it. Thank you.
Looking at the tank it is fairly typical of the state of most tanks I come across while doing Legionella risk assessments
Your Landlord may have done a Legionella risk assessment on your property which may or should have recommendations, you could ask to see it.
How safe it is would depend on what the tank supplies, if it is only hot water and the hot water temperature in the cylinder is high enough to kill off anything harmful, it is probably safe to use, without seeing the entire system I cannot be definitive. its not ideal and should be sorted. Ie cleaned, fitted lid and lagged.
It was probably fitted before the bylaw 30 tanks were bought in, which included lids lagging fly screens etc, you will always get some build up of scale depending where you live which does need to be cleaned off
If you want to read up more on Legionella hopefully these links will work.
Legionnaires' disease - Technical guidance - https://www.hse.gov.uk/pubns/books/hsg274.htm on this page look for part 2 of hsg274 as a pdf, download it
it shows various examples of tanks and recommendation action page 25 onwards
good luck
Thank you for the reply. It also supplies the cold water too. It is the mould that floats on the water when it is full too that is gross. I am certain my landlady won't have done a legionnaires check. She doesn't care about dangerous faults until environmental health make her.
Tbh doesn’t look too bad just needs a clean I suspect the stuff you see isn’t mold it’s more lime/ calcium deposits
Also you shouldn’t be drinking that water as it’s not for that
You can't see them in those photos but they are black in the middle with lighter edges that float on the water. They are water mould. They were obvious when the tank was full. We used to use the water in the bathroom to wash our faces, hands, brush our teeth and shower. I don't think it is safe anymore. I agree It needs a good clean out.
Get the council out under health and safety and get them to order your ll to do / upgrade the tank to a bylaw 30 one
Reply to Does this water tank look dangerous? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, Just recently noticed the overflow has started pouring water out, there are three tanks in the loft and I'm quite sure this is from the...
Hi everyone, I have a question and hope for some advice or information on the following many thanks; How long should tap water be left out at...
I recently took off an end stop on the vent/expansion pipe over the heating header tank. I now know why it was capped off. When the 2 way valve...
2K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi everyone, I moved into a new build three bedroom, two bathroom bungalow about 2.5 years ago. Ever since we moved in there has been an issue...
6K
