Discuss do I need to wrap (duct tape) or sleeve, plastic piping going into concrete floor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matty Birch
hi just wondering which is the best way to go about it, have a radiator to be fitted in a conservatory and the customer wants it to be chased into the concrete floor.
Re: do I need to wrap (duct tape) or sleeve, plastic piping going into concrete floor
Dont put a radiator into a conservatory. Not worth the hassle.
Insulate.
thanks what would you suggest using?
Kooltherm wrapped in denso. With a zone valve attached
There will be big heat loss in the conservatory. I wouldn't bother... Customer will always be complaining.
lagged pipe in pipe would be ok, if your customers wants to waste money fitting rads in a temp building thats there choice. Custards are always right if they are paying well enough.
Reply to do I need to wrap (duct tape) or sleeve, plastic piping going into concrete floor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
I have some internal water pipes (some plastic, some copper) that have to go under the kitchen floor. There is no way around having to do this...
TAGolko
T
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
