Discuss Danfoss RAS-C2 removal in the Central Heating Forum area at PlumbersForums.net
Hi I have a valve (see picture) that won't come off when I've unscrewed the ring - is there some sort of screw that needs u
nscrewing please?
[automerge]1578915606[/automerge]
Pull straight up will come off
As above.^^^
The ring locks the plastic tabs down onto the valve body, it should pull upwards.
Don't move it side to side too much, the tabs may break off.
Reply to Danfoss RAS-C2 removal in the Central Heating Forum area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of...
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I...
Hi everyone, my first post here so go easy on me... 😄 I have Danfoss HPA2 motorised valves fitted to my heating system and one of them is giving...
This is driving me bonkers! I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early...
