Discuss Danfoss odd noise coming deom in the Central Heating Forum area at PlumbersForums.net
Hiya, any help would be great.
I have recently moved into a new house (4 days ago) and only notice an odd noise the last 2 days.
Managed to track it down and it’s coming from a the Danfoss dual units (specifically not the one by the wall). Any help with it would be great as it doesn’t sound healthy. It’s warm to the touch compared to the other unit.
What do people think could be causing this?
  • IMG_7101.MOV
    10.2 MB
The noise is coming from one of those zone valves closing which perfectly normal. It's warm because it has been open allowing hot water from your boiler to flow through it.
One valve controls hot water going to your radiators, the other to your hot water storage cylinder.
Thanks for your reply!
Any noise in a new house makes me panic! Do you think it’s trying to heat up the radiators in the room as each floor has a thermostat (which is triggering it).
But, it just doesn’t know that my boiler is only set to hot water atm and not radiators? Which is why it’s happening so often?
I possibly made an incorrect assumption about your system if you have more than two floors or heating zones. How many of these zone valves do you have?
But no, if it's working as it should and only your hot water is on it'll be the hot water zone valve that is opening and closing. Are any radiators heating up?
Set the hot water timer on your main controller to come on for a set time in the am and pm (for now) only instead of being permanently on.
Frequency and duration when charging the hot water cylinder will ultimately depend on how often and how much hot water you use throughout the day and evening.
Reply to Danfoss odd noise coming deom in the Central Heating Forum area at PlumbersForums.net
Hello, the edge of the end of my bathtub leaks when I am about 3 minutes in the shower. The faucet is on the opposite side. What could be causing...
C
Apologies - I am not a plumber - not sure if it is ok to post here but... It's freezing and my boiler is not working so, I wonder if anyone can...
Evening All, Been having on and off issues with a Greenstar CDI classic Combi were the hot water is not heating up but only intermittently. Some...
Hi, moved into a home a year ago with what is probably an old heating system. There is a gas boiler linking to radiator central heating, and a...
Hi everyone! My Worcester Greenstar 30CDi Combi boiler started making a rather loud juddering noise two nights ago. I bled all the radiators and...
Deleted member 120897
