Discuss Danfloss wireless thermometer and receiver in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ana
i have set the thermostat but the receiver doesn’t kick in. If press the Ch button it comes on then off. So I don’t have any heating
If I put the programmer on constant heating. I still don’t have any heating.
Any help much appreciated
Quite possible that the thermostat is fubar. Is there an override button on the receiver?
Receiver could also be faulty if you are pressing button on it and it goes on and then off in a couple seconds
Reply to Danfloss wireless thermometer and receiver in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar 18Ri to short cycle. So, the moment it gets cold outside my boiler works for about a minute, then stops, and starts again in about 5 minutes, then...
2K
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame to call for heat, and the receiver seems to be working ok with green light, but heating is just not firing. I really am not sure what the problem is...
I have a ideal logic 30 boiler ,the thermostat receiver looks to have died ( no lights on wired receiver ) I believe this need# replacing but in the mean time does anyone know if I can override the thermostat if heating is required please? the handheld thermostat is working it’s the boiler...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer) This programmer is connect to a terminal strip using 345 (three...
