Discuss Ct1 miracle seal any good. in the USA area at PlumbersForums.net
Has anyone used this? Is it good or has it caused issues with clogging parts of the system up.
The proposed job is a combi boiler with microbore piping feed through 2 manifold. This could be an problem I guess.Last resort mate and never on a combi type system it is good stuff we had a trade day demonstration, but for me personally I don't like using anything that could possibly clog up any water ways so as I said only use it as a last resort and only on a open type system . Kop
Block up the manifolds?Yes mate I wouldn't do it will block up .
They said put it in at a radiator furtherest away from the boiler so it will be diluted by the time it gets back to the boiler. Problem being then is the radiators are fed up 10mm pipe back to a manifold.And more likely the plate hex waterways, and depending on combi,main hex waterways
Block the pipework and restrict the manifolds at a guess not worth the risk .Block up the manifolds?
Reply to Ct1 miracle seal any good. in the USA area at PlumbersForums.net
