G
Goinker
I need to fit a 1010mm high x 310mm wide radiator on a 440mm wide wall, so was intending using a 15mm 'Corner TRV' and the matching lockshield valve under the rad so these don't stick out beyond the wall ends. I'm told that these type valves are for towel rail use, not radiators, although with a radiator of this small size, output wouldn't be that much different from a towel rail, so is this a flow handling through the valves issue, not a recommended setup, or what? I want to keep visible pipework to a minimum, so was intending piping through the wall, but if corner valves are not usable, what's the next best way to go?
Cheers.
Cheers.
