Discuss copper pipe clips what do you recommend for 22mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Eyespy999
Morning all.
I am running some 22mm copper later today, I normally use Talon clips from screw fix, as you can add on spacer blocks for the gap, what other plastic clips do you uses, recommend? I have some munsen rings for an outside run.
Thanks in advance!
Talon clips also for me, though they don't look great clips. I like that there are spacer blocks available for bringing them out from wall if needed.
The Munsen rings are hardy for outside, but I hate that they need two accurate holes drilled.
The rubber lined Munsen rings make a nice job for inside work, especially hot pipes as they have the rubber around the pipes.
I prefer clips that only need one centre fixing.
Have you tried the masonry single bolt fixings for these for interior work?
You can get a male threaded stud for clip to screw directly on or a female thread, for to use whatever length of thread you can cut.
You just need to drill one pilot hole for centre of clip in solid walls and use an impact driver to drive the fixing in. Very simple and strong way of installing a lot of pipe runs and only needs a centre line marked or use a laser to mark your drill points.
BES does, or used to do, a plastic locking clip that looks nicer than the Talon locking and interlocking clip, but feels weak and so I bought them just once to see what I thought of them and have stuck to Talon since.
Sometimes an offcut of 15mm pipe behind the clip makes a better spacer than the Talon spacers as you can make the precise thickness you need - handy for uneven walls.
Reply to copper pipe clips what do you recommend for 22mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a copper 22mm gas pipe about 10m long fitted to the outside wall by a Gas engineer using plastic clips with spacers. The clips have become...
3K
Hi All, I am in the process of renovating a property and have the floorboards up installing cabling etc, however it is the plumbing that I have...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
