Discuss Connecting trap to drain stub out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
HKM
Hi all, this is my first post and I am trying to fix a problem left behind by a silly handyman. The kithchen sink p-trap has come off the waste drain spout. I can't figure out how to seal the trap to the drain spot without leakage. There is no thread on the drain spout and if I tighten the ring on end plastic ring on the trap then it simply leaves a gap between the drain spout and trap. Water is falling through this gap and the trap easily pulls off the drain stub out. What is the way to seal the drain stub out to the trap? Is there a sealant to be used or is there a part/washer missing? I have attached two picture, one of the stub out and one of the trap end. Hopefully I am clear in my explanation. Thanks in advance.
You need to remove the black rubber washer in the trap if you look deep down you will see it
Slide the nut onto the pipe
Then the plastic washer
Then the rubber seal
Then seat the trap full into the waste pipe and push the nut washer and seal to the face of the threades and tighten the nut
Thank you! Going to give this a go.
Reply to Connecting trap to drain stub out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
