Discuss Condensate external or drill through from garage in the Gas Engineers Forum area at PlumbersForums.net
Matt0029
I'm on a new build the boiler is in the garage. I have the option of drilling straight out with the condensate in to the stack. Or drilling through from the garage to the house to tee in to the kitchen sink waste. So it's either coring out and coming out with that black dot is.
Or coring though to the kitchen sink under the plyth to connect to the kitchen. Waste. If the pictures sort of make sense. What would people think was best please
Yep, internal if I have the choice so you can also stick to mostly 22mm indoors or whatever's most practical to install. Plus you're coring cement block instead of stone.
Garage you need to run 32mm so just run it all the way
The sink waste does go external the stack but it's a tiny external run. An elbow 100mm but of pipe and street elbow. Still best of doing it like this as the kitchen sink would flush it stop it freezing. Sounds logical?
Whatever is easiest mate, I usually like running it internally and keeping it 22mm if I can so the only real aggro is finding where to put the boss on the outlet but if you have no room you have no room so run it to the stack outside.
Reply to Condensate external or drill through from garage in the Gas Engineers Forum area at PlumbersForums.net
Engineer has installed several boilers for me. All the condensate pipes have been connected externally into soil stack or rain water downpipe. In...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
Hi all, My boiler was kind of new & installed last year July, I know there's build-in frost protection. Also, there's an old external frost...
I'm in a house with the cold feed coming up in the kitchen. In 25mm mdpe. The boiler is in the garage adjacent. I plan on running the cold from...
Hi, I live in a house that is 20yr old. There is a single soil stack running from the top floor (of three) through the first floor bathroom and...
