Currently reading:
Condensate boss into washing machine standpipe?
Discuss Condensate boss into washing machine standpipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JCplumb
Hi guys,
got a job coming up where one of the issues is the kitchen fitter connected a condensate pipe to a washing machine standpipe by drilling a 22mm hole and siliconing the condensate pipe from the combi into that...
Surprise surprise - it is now leaking.
I would like to know if regs are happy with the idea of this, not the way it has been done here, just the general idea of running a condensate pipe into a standpipe via a tee. If so I would be trying to get hold of the below item.
I've looked at my usual plumbing suppliers and can't find one anywhere, will start ringing the independants if regs permit this.
Thanks in advance for any replies :)
Hi JC i put them into stand pipes, nothing wrong with that. You can buy a rubber seal that will fit your inch and half tee to take a overflow pipe.
Yeah I saw the McAlpine clamp while browsing, that's got a solvent weld boss on if I remember correctly. Cheaper than the polypipe one I pictured too :)
Will find out what the merchants have if I get the job, they haven't got back to me yet, about 6 jobs need doing to correct some 'handyman' work they had done...
Not acceptable unless the MI's specifically allow it.
The condensate pipe is classed as part of the flue.
i always see that as a debatable statement if its part of the flue who decided that overflow pipe was a suitable flue or that a soil stack thats tested to 3inches water is sound enough to use as a flue and is a durgo sound enough to be part of a flue system?
Thanks for the advice guys but I didn't get the job anyway :( , someone seems to have come up with a lower quote - the blighters! (unless it's Kay-Jay)
I quoted £135 for the following
repair leaking kitchen mixer tap (just new o-rings on the spout)
repair leaking bathroom mono (new cartridge)
repair bathroom filler/shower hose combo thing. (not sure why it was dripping, but likely diverter - so new o-rings)
renew silicone round bath and basin.
supply/fit proper fitting to connect leaking condensate to stand pipe.
I thought it was a reasonable quote as any of those jobs would be £40-50 on their own, should have asked him how much the other guy quoted...
Reply to Condensate boss into washing machine standpipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
