Peanutbutter
Hi
I am renting a flat with a communal heating system. The boiler is gas fired and was new in the summer. The flat is on the ground floor (the only one) and it has old iron radiators (building is pre-war). The is no temperature control apart from valves on the radiators. The flat was lovely and warm but just before Xmas I noticed it started to get cold. All the radiators were warm at the top and cold at the bottom. I was away at Xmas and when I came back the radiators were at most lukewarm or cold even though the valves were fully opened.
I informed my landlord and the heating maintenance "engineer" came round who bleed the rads but there was no air in them. This did not cure the problem so he came round again and did the same then starting banging the pipes with a hammer.
The rads are still cold however the rising pipes (two in different locations in the apartment) are very hot and the return two return pipes are warm. The rads are fed off these individually but each pipe feeding the top of the rad is cold and the pipe to the bottom is lukewarm.
The heating company has now told the landlord that it is problem with the rads valves and that to fix the problem they have to drain the whole system which they are not willing to do until the summer.
The apartment is in Paris but I am from the UK and my french is not good so I am not sure I am being spun a line. I cannot believe that all the valves broke at the same time. Any thoughts? (apart from move back to UK - work!)
Tom
Tom
