Hi ShaunJust fit the combo valve eg prv at your mains stop tap or a secondary pressure reducer to keep the whole system at the same pressure
First thing to do is get a heat loss done then you know the load of the new boiler
I’ve got a new mains being fitted beginning of March. I’ve asked for 32mm which will terminate in the garage. I’ll do a temp connection to the existing in 22mm pex which I already have but ultimately it needs to feed to cupboard where new tank will be. This will need to run under the floorboards, can this be done in 28mm pex/pb pipe?
Many thanks
