Currently reading:
CO2 Settings
Discuss CO2 Settings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 64964
Hi Guys,
I was wondering like the fantastic voltage and ohms PDF that was kindly posted for us to copy, has anyone supplied a burner pressure (not as necessary as data plates generally have it on) but CO2 setting for all the different boilers In a PDF?
as you have got the manufacturers instructions open anyway just read the tech table.
I don't need the manufacturer instructions on most boilers as I know them pretty much inside out, what I can't remember for all is CO2 like glowworm flexiboms for example some are 8.6 some are 9.1 and some 9.3 it would just be nice to have a list.
Hi Guys,
Hi, could you please send me the voltage and ohms pdf, it would be great to see it.
Cheers,
Tony
Thats why you need the instructions. if your going to bother opening a book or pdf then just open the correct manufacturers instructions for that model and version/year.
as im sure you know you should not work without the instructions. Saying you cant remember specific values proves you need to have them with you.
I always look them up, hence why I am asking if there is a list which would be quicker than having a PDF for every boiler.
Cheers,
Tony
I belive it's posted in the private gas safe forum in boiler breakdown section
i would only trust the figure from the MI unless you have colated the table.
why dont you make one for the forum? ;)
I was actually considering it until you picked on me :disappointed:
Seriously though I might start putting something together
make it with ppm,ratios and action levels as well as alot of boiler doh need the co2 values.
Look at you putting your requests in lol
Yea I agree it would be a lot more thorough if it included action levels etc
it would be quite a project but I suppose it could be the common ones to start with.
Reply to CO2 Settings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
