Discuss Changing shower controls to mixer in the DIY Plumbing Forum area at PlumbersForums.net
Hello.
I have a shower with twin (hot and cold) taps which feed pipes hidden in the wall which go up to the shower outlet from where the hose is attached. Now I want to change those taps and replace them with a mixer having just the one control for temperature and water pressure.
However, looking for this mixer I can only really find ones that have the hose attachment also (which I don't really need because the hose of mine is already attached higher up the wall), or which are too small to completely cover the pipe outlets (which are 16cm apart) in the wall.
Generally, though, I'm not sure I can buy a normal mixer because of the way that the water goes up the pipes to the outlet higher up the wall, rather than through a hose attachment on the mixer as most showers have. Can anyone give me some information about what type of mixer I can buy and where I might find the type that I think I'm looking for, or will a normal mixer do the job somehow?
Thanks in advance for any information.
Below are pictures of the shower and the pipes as I can see them when I take the taps off, and an example of the type of mixer I'm looking for:
No type of shower valve will fit on what you have, the pipes behind the wall need re-doing.
The controls you have are just a tap head on each of the supply pipes in the wall, pretty unusual set up.
Even if you could somehow attach a mixer valve externally, the way that must be piped means the supply will still just bypass it and come out of the shower head without any controls affecting it.
Reply to Changing shower controls to mixer in the DIY Plumbing Forum area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
